Mode shapes are strange
I Etabs model of multistory building, I get mode shapes showing large deformation of the slab, each mode shows different part of the slab moving up and down in no realistic way. Does anybody have a solution for this? The slab was modeled as ribbed slab using the deck section.
RE: Mode shapes are strange
What you describe may be correct - note that a mode shape as shown in a model has no direct physical meaning. The mode shapes are normalized based on the way they must be calculated - so a modal deflection of 3.2 is only with respect to a control point set to 1 or whatever the program assumes. They are more for understanding problem areas, and they are used with a forcing function to determine the structural response.
Do you have the slab modeled as a membrane or with very small stiffness modifiers? If so, that could be the source. I've had this issue when I would adjust wall stiffness modifiers to force all load into in-plane bending and all of a sudden my major mode shapes are all out-of-plane bending of the walls.
my slab modeled as deck to represent one way ribbed slab.
Solved.
It was loose connections of some beams not slab, that drag the slab with them.
