Cannot Compute Arc
Cannot Compute Arc
Cannot Compute Arc
I'm getting this error when updating a detail view on my drawing (nx 7.5) any Ideas how to fix/what's causing it?
I can get all views to udate but the drawing itself won't
RE: Cannot Compute Arc
Send the NX file and/or a picture......
Did you intend to post an image of the error?
I can't.
though editing the view boundaty cleared the error.
good to know
Though it now seems that this has directly led to that mysterious missing view circle problem
Ok now they're back though I don't know how or why though I'm still having problems selecting some of the views (I have to go throuh a specific command to select them can't pick the boerder on the screen)
Ok found out the problem. Background clipping is hiding the view circle (even though the base view has the same clip plane)
Is there any way to move the view circle so it wn't be hiddne by the clip plane?
sorry for the typos
no clue if you can move the circle, but you should be able to edit the view, ( double click) Perspective tab- Fit planes to extents.
Tomas
problem is it puts the circle right where the information I don't want to show is I had to VDE it all out (alot of work to get around what seems to be a programming oversight)
problem is it puts the circle right where the information I don't want to show is. I had to VDE it all out (alot of work to get around what seems to be a programming oversight)
