Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is a very good site. Please keep it running. Thanks and wishing a great health and success for the site and its owners..."
Geography
eit09 (Civil/Environmental)
18 Sep 12 16:14
I clicked on the developer tab in microsoft outlook and saw the ability to writ a macro. Unfortunatly there is no macro record button like in excell. Each week I have to attach a document (same file name just updated file) that is always located in the same loaction on my pc. I would like a write a macro to attach it this document automatically. I tried to creat a simialr situation in xcell with the record and copy it into the code but no luck. Below is what I tried to write with the code. Any one know if what I am attempting is possible?
Sub Timer()
ChDir "H:\Timer"
Workbooks.attach FileName:="H:\Timer\Jason-Time-Sheet.iif"
End Sub
MintJulep (Mechanical)
19 Sep 12 13:13
Yes, it is possible.
19 Sep 12 14:27
MintJulep,
Thats great news. I write the follwing script in the vba editor but the macro doesn't run. I have never acutally stepped into the macro and typed commands I have only used the record macro xcell has. Could you take a look below and comment?
Sub Timer()
ChDir "H:\Timer"
End Sub
19 Sep 12 14:38
Your code won't do what you want.
Try something like http://bit.ly/UjDEUu
bacon4life (Electrical)
19 Sep 12 14:54
There are lots of ways to automate this using either Outlook, Excel or the Windows task scheduler.
One way with Outlook would be to create a weekly reminder on the calendar, then have the reminder trigger sending out the email. This link shows how to send out emails based on calendar reminders. You should just need to add an if statement so it only sends the email for your specific weekly reminder, then add the file location in the SendPage subroutine.
http://support.microsoft.com/kb/236774
If you have both outlook and excel running, you can have excel send out an email. One drawback is that Outlook will have a dialog box requiring you to approve excel sending out an email on your behalf.
http://www.rondebruin.nl/sendmail.htm
Another way is to download sendemail.exe from http://caspian.dotconf.net/menu/Software/SendEmail....
Then create a *.bat file that contains the command line parameters for sendemail.exe. Finally, using Windows task scheduler to run the *.bat file once each week. You would need to ask your IT department for the IP/Port number of your mail server as well.
*.bat file
"sendemail.exe" -f fromaddress@youcompany.com -t toaddress@youcompany.com -u "This is the subject" -m "This is the contents" -s 101.0.0.0:25
yakpol (Structural)
20 Sep 12 19:01
eit,
Try this code from Excel VBA. Modify email parameters at your will.
CODE
Sub SendEmail2()
Dim myItem As Outlook.MailItem
Dim myolApp As Outlook.Application
Dim myRecipient As Recipient
Application.AutomationSecurity = msoAutomationSecurityLow
Set myolApp = CreateObject("Outlook.Application")
Set myItem = myolApp.CreateItem(olMailItem)
Set myAttachments = myItem.Attachments
myAttachments.Add "C:\MyPath\MyFile.dat"
With myItem
    .Importance = olImportanceHigh
    .FlagIcon = olBlueFlagIcon
    .ReadReceiptRequested = True
    .Subject = "You won a lottery!"
    .To = "MonikaL@whitehouse.gov"
    .Body = "Hello my dear..."
    .Display 'optional
    .Send
End With
End Sub
cheers,
Yakpol
IDS (Civil/Environmental)
20 Sep 12 21:57
A useful resource for using VBA in Outlook is:
http://www.jpsoftwaretech.com/category/outlook/
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
21 Sep 12 12:01
@ YAKPOl
Your Code worked great the only thing I need to tweak now is to keep my signature message (contact info) that normally is applied whenever I create a new email. Do I need to add something before the attachment portion of the code to start by opening a new email?
For the code to run I had to delete two code lines "Application.automationsecurity = msoautomationsecuritylow" and ".readreceiptrequested = true" Do I need to be aware of anything by deleting these two lines?
Thanks again!
yakpol (Structural)
21 Sep 12 13:13
eit,
To add your signature you can add a string to the myItem.body
CODE
strMessage = "Hello dear..."
strSignature = vbcr & "My name" & vbcr & "My address" & vbcr & "My phone"
MyItem.body strMessage  & strSignature
vbcr serves as a line breaker.
Security option and read request are optional.
hope it helps.
Yakpol
Close Box
Join Eng-Tips® Today!
Join Us             Close
