PCBs and Gas Chromatography Question.
Hello all,
I am doing a paper on using Gas Chromatography for the analysis of PCBs in a sample on pond sediment.
What sort of column to use, which detector is best and why, etc?
I've been searching for info and I thought I'd try the forum community as well.
Does anyone have any good ideas on where to find information, or has anyone any experience with this
sort of analysis?
Any info would be greatly appreciated.
Many thanks,
Owen Lewis
Chem-Eng, University of Toronto.
sort of analysis?
Many thanks,
Owen Lewis
RE: PCBs and Gas Chromatography Question.
I've done a bit of work with GC long ago but the d=info is still current (I think). The type of column you use depends on what else is in the sample soup. Temperature and sample through put as well as turndown among samples will also be factors. FOr low concentrations (envoronmental levels) a GC MS or EC would be best.
The best information would come from Hewlett Packard or Perkin Elmer. Each has a help line with technical tyoes who will have the exact info you need right at hand
Hope this helps
Contact Eco Logic in Rockwood, The build PCB chemical destruct units. 519 856 9591
Paul
