Fire Water Requirements for Vessels Under Construction
I'm looking for guidance on fire water requirements for vessels:
- Under construction in a hall
- Under repair/retrofit in a hall
- Under repair/retrofit in dry docks and while at lay up on a wharf
I note that there is guidance in NFPA 312. However, does anyone know of any other similar codes/standards (NFPA or other) which would provide any further guidance on flowrates and pressures required in the shipyard industry.
Thanks in advance,
TS
Thanks in advance,
TS
