TSA coating breakdown factor !!
I am looking for tsa coating breakdown factor to use for the anode requirement calculation.
currently working a tsa with anode system!!
RE: TSA coating breakdown factor !!
If you are using DNV-RP-B401, then by the definition of 'coating breakdown factor', it is 1. You are given the current densities to work with in sub-subclause 6.3.11.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Hi Jones,
Thanks for the information.
Just need to clarify this coating breakdown factor , is this 1 is the initial value or the mean value .
is there any calculation for the thickness of tsa coating requirement available!!
