Choosing a boiler for use in acidic environments
Hi all,
occasional lurker here, decided to make my first post.
I'm trying to choose a replacement boiler for our open loop (once through) wash process. Currently we have a 1.2M BTU copper-fin Dura-max boiler but we have had problems with the copper heat exchanger because of the acid used in that area. We plan on moving it as far away as possible, but there will still be some exposure to acidic air. All water is coming fresh from the city, through our water softener and into the boiler which maintains a 500 gal tank at ~120-140F. I'm looking for advice on choosing the most cost effective unit: Balancing unit durability, cost or replacement parts, and efficency (obviously). I've gotten some quotes from people for copper-fin boilers, and other telling me that cast iron is the way to go with the ammount of water we run (1500+ gal/hr). Any idea? Sorry if more info is needed...this is the first boiler I've had to spec. Thanks much.
Dave
Dave
RE: Choosing a boiler for use in acidic environments
We go through about 55 gallons per week. A maximum of 32oz of acid is added to ~60 gallons of water for burnishing parts. There are 3 tumblers. Water is not agitated enough to create any noticeable mist. Steel mezzanine and copper pipes in the area do not have problems with corrosion.
air intake from outside. Roof or walls.
you will loose some eff. on the first and a lot more on ss. condensing will help but is the acidic air will kill the copperfins and tubes before getting to the condensing section. dont forget the sealed combustion which is std on most decent heaters today.
contact an expert tom at American hydronics milbrae CA
