Rotating a liner during cementing
I was hoping to quantify the torque required to turn a 7-5/8 39lb/ft (ID-6.625) liner in an 8-1/2” newly cemented hole. Assume no inclination in the well bore. This is not a special case; I just want to get the formulation down. From dynamics we know that T=I*ω. The moment of inertia is not that hard to get, but how can we account for friction due to the cement. The formulation must include the fluids and I am not sure how to set it up. Any help is appreciated.
RE: Rotating a liner during cementing
If you really want to know the required torque then friction is far more significant than moment of inertia. Well deviation almost always exists. If you can find the torque during drilling when bit was not on bottom this may give you some idea.
I’m just not a fluids guy and a reference to any publication on the Torque required to rotate this liner is appreciated.
