How would I be able to use teamcenter to check in all models, objects boms, ect that i have checked
How would I be able to use teamcenter to check in all models, objects boms, ect that i have checked out.
Is there a way I can query for all things I have checked out.
-Thank you
RE: How would I be able to use teamcenter to check in all models, objects boms, ect that i have checked
In Teamcenter, do a general search and pick the little down arrow to get a list of search types, and select "Checked-Out Objects"; by (your name). Execute.
In the search results window, highlight the checked-out objects all at once then right-click and select "Check-In". To confirm, just right-click the top item in the search window and select "Refresh". Start a new search for "Checked-Out Datasets" using this same method.
That should get everything checked back in for you...
Back to the drawing board,
Doug
Senior Drafter
NX 7.5
