Help locating holes in 3D space with reference to axes
I need so help, I am dimensioning a rather complex part which has a couple dozen holes at non 90 degree angles on a non flat surface. I need to locate these holes in 3D space referencing to some axes that I designated. I've tried dimensioning them using smart dimension but no matter what I do it doesn't work. This is an imported file, and I don't have access to the original file in whatever program it was drawn in, so I can't look at hole wizard or the original sketches. All I want is the ability to find these hole's xyz position with reference to some axes and the angles they make with the different axes.
I am about to pull my hair out.
Any help would be appreciated
RE: Help locating holes in 3D space with reference to axes
I am off my game today
- - -updraft
