Inflow air required for vacuum tank venting
I'm sizing the vent for vacuum tank in condition of cold spray after hot washing, Could any one help please giving the formulas for this calculation, the aire venting and the air inflow required, in order to size the vacuum valve.
the data given is: MAV(Maximum allowable vacuum)for the tank ( psi), Cold spray temperature (oF), cold spray flow (lbs/h).
Thanks.
Laurent.
