Pipe Clamps Design
Pipe Clamps Design
Pipe Clamps Design
Hi
Do you now where I can find some information about the design for pipe clamps ( service: Mud 700 bar rating 10000, Cement and Production 1000 bar rating 15000 ) like plate thikness, radius , bolts, holes diameter etc. as minimum
Pipe Material AISI 4130 PER NACE
RE: Pipe Clamps Design
Opensource (Mechanical)
GOOGLE SEARCH FOR api 10000 clamp
api 10000 clamp [XLS] API 16A Hubs and Clamps.xls
[XLS]
www.at-engineering.co.uk/.../API%2016A%20Hubs%20an... Format: Microsoft Excel - View as HTML
8a.API 16A Hubs and Clamps .... 113, API Type 16BX Integral Hub Connections for 10,000 PSI Rated Working Pressure. 114, Nominal Size and Bore B, Outside ...
