Static versus Dynamic (impact) load
Hello Everybody,
I am trying to analyse a composite tube impacted by a certain mass (50 kg) drop at a height of 3 m (velocity = 7.7 m/s). What would be the relationship between the static load (m x g) to the dynamic load (drop at a height of 3 m)?. Obviously, dynamic load should be higher than the static load. I appreciate your help.
Regards to all and thanks lot.
Nestor
Nestor
RE: Static versus Dynamic (impact) load
But, the problem with this approach is that you have to assume a d to begin with so that requires an iterative process.
Therefore assume a deflected distance that you think is reasonable and use it to generate the resultant force. Apply that force to the system and check the deflection. If it's close to what you assumed then refine the calculations to the degree of accuracy you want. If it's not close to what you assumed, do the same thing, but with larger modifications to your assumptions.
And, of course, watch your units.
2) please don't multi-post, RF one or the other.
v0=7.7 x0=0
v1=0 x1=unknown
1/2*m^v0^2=1/2*k*(x1-x0)^2
then peak acceleration=k*x1/m
How does that compare with your answer?
Cheers
Greg Locock
