Everything you will ever need to understand pumps
5
Artisi (Mechanical)
Stumbled across this info which looks to answer all your pump questions. 100 + pages ranging from basics onwards. Well worth a look.
RE: Everything you will ever need to understand pumps
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Did you write this personally or is there a source or sources that you can share?
Not my work, was searching for info on air-entainment and stumbled across this. It came up on a link that was completely unrelated to its heading.
No author, reference or any further info.
Thanks for sharing Artisi. A star for 'ya.
rmw
I'm not claiming it to be mine, but I did a FYP on the correlation of axial thrust in water pumps. The background data was very similar, that's all.
A very good reference document none the less...
Adrian
--Winston S. Churchill
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
VPL, anywhere I can transfer a file to you?
Patricia Lougheed
