Eliminate stress concentration in ANSYS 13
hi, i'm using ansys 13 and try to see stress distribution on human teeth. But i have very high stress value at the surface which I'm applied the load. can someone help me how to avoid the stress concentration in my work? Thanks
RE: Eliminate stress concentration in ANSYS 13
if the stress peak is going beyond the yield of the material ('cause you're using a linear stress analysis) then use non-linear.
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
give us a pic, tell us why you think the stress peak is unrealistic ...
Tobalcane
"If you avoid failure, you also avoid success."
“Luck is where preparation meets opportunity”
"People get promoted when they provide value and when they build great relationships"
