Hole Tolerance Question
I am trying to perform a tolerance stack up on a small assy. I have:
Block w/ Hole ID - 0.309 +/- 0.002
Bushing OD - 0.307 +/- 0.005
Bushing ID - 0.250 +/- 0.005
Pin OD - 0.244 +/- 0.002
I want to put the bushing into the hole and put the pin into that. I have never done a tolerance stack up on anything except examples (none of which I had anything like this).
Right now, my idea is to cut it in half and just do half of the stack up so it represents a more simple stack up.
Could someone give me direction on how to do this?
J
J
RE: Hole Tolerance Question
Worst case fit of the bushing into the block is minimum block hole dia - maximum bushing OD. So .307-.312 so .005 interference - which may be a bit aggressive depending on factors you don't list.
Likewise Min bushing ID -max pin OD. So .245-.246 = .001 interference which again I don't know if that's appropriate for your application or not.
If you want to find max slop then do the opposite calculation.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Right now it seems that all fits are transition. You just need to compare:
#1:
a) min. ID of hole with max. OD of bushing;
b) max. ID of hole with min. OD of bushing;
#2:
a) min. ID of bushung with max. OD of pin;
b) max. ID of bushing with min. OD of pin;
In both cases there will be an interference in a)'s and a loose in b)'s, so this is typical transition fit.
My question was not using worst case, I figured that out. I was wondering if I was using the RSS, more specifically if it was okay to take off from the outside to the center and then just double everything to get the entire hole tol.
J
Powerhound, GDTP S-0731
Engineering Technician
Inventor 2013
Mastercam X6
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
With that said, it will fit down to a .305 hole if my math is correct, before that gap closes. Thus making it a slip fit all the time.
My asking for the RSS tolerance stack up is mearly because I am not sure if my method of doing this (in this scenario) is correct and I wanted to see if someone could tell me if my method works.
WC right now, I believe will have a .006" press fit. I would rather it be slip fit because we are putting a rivet (the pin) through the center and right now I am not sure how much that will expand.
