Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Praise should be given to the Forum managers or the Tipmasters - they are what make it work - give them extra recognition!!! They are timely (prompt - unlike ACTUAL support sites) and on the ball!!!..."
Geography
JoeMarfice (Industrial)
13 Sep 12 14:44
I have a structure that "meanders" - it is composed of both straight sections and curved sections. I need a precise measurement of the entire structure, preferably as a dynamically linked dimension.
Measure>Continuous allows me to measure each of the segments (although it seems I might have to use piecewise linear approximations to the curves), but even that command doesn't allow me to sum them all up automatically.
Doesn't seem like this shouldn't be possible, but I can't figure out how to do it.
Helpful Member!(2)  Ericsonbirdman (Mechanical)
15 Feb 13 12:07
The easiest way to get the length of a "meandering" line is to convert it to a Polyline and then open the properties window (or use the getarea command).
To convert a line into a Polyline:
1. Enter "editpolyline" into the command window
2. Select a line to start with
3. Enter "Y" to turn the line into a Polyline
4. Enter "J" to convert other line segments into a single Polyline
5. Select line segments to convert into a Polyline
6. End the command
To get the Length of a Polyline:
1. Select the polyline
2. Open the Properties window
or
1. Enter "getarea" into the command window
2. Enter "E" to specify the Polyline Entity
3. Select the polyline
Close Box
Join Eng-Tips® Today!
Join Us             Close
