Pile and Pile Cap
Pile and Pile Cap
Pile and Pile Cap
Hi, I have a question about grade beam, pile cap and pile connection. Is the connection between the pile and pile cap supposed to be pinned or fixed? As I understand, we do not want to transfer moment on foundation. If pinned, what kind of reinforcement detailing would be warranted at the pile-pile cap connection?
Appreciate your help.
RE: Pile and Pile Cap
it depends on how you are designing for the load. normally i would suggest pinned although to my mind most detailing would more likely allow some moment transfer. typical detail for a pinned head would be one or two bars projected up into the cap. unless its a precast segmental pile ot steel tube with cap plate. or h pile. SO to answer the question it depends on how your dealing with loads and the type of pile.
You only have to put enough steel across the joint to take any shear or uplift, no moment.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
generally agree mike but sometimes we do. can save piles
