delay starting problem of EDG
We have 03 mtu EDGs of the same type having model # 12V 956 TB33.
Recently we are facing problem in our one EDG Engine , the problem is delayed starting of EDGs, it takes about 20 Sec. to reach its required RPM, while our requirement is, that the engine must start and reach at required RPM with-in 12 Sec. we have all the checks recommended in the vendor manual but the problem could not be resolved. e.g. checking of fuel system starting air system charge air system and all its related components and equipments.
It is to be noted that normal starting history of the engine, before this problem was about less than 10 Sec. same is for the rest of 02 engines.
if some one can help / suggest for resolving this issue.
thanks
thanks
RE: delay starting problem of EDG
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
this shows that the problem is in mechanical not in electrical systems, however required electrical checked of starting system, AVR, excitation system were checked & found OK.
If you enter enter a document content of "diesel generator" and a document type of "NRC Information Notice" you will get approximately 400 Information Notices that the NRC has issued over the last 20 or so years of problems identified with diesel generators. In reading through those you might find something that speaks to your problem. I don't know.
Patricia Lougheed
