Trying to find a solution to this attribute error. Is it a glitch?
We are on NX8.0.2.2 and I am trying to update a drawing. This is the error I get. "The attribute corresponding to an attribute handle cannot be located". This has happened several times and it's getting really annoying. Anybody else had this happen and have you found out what is causing it?
RE: Trying to find a solution to this attribute error. Is it a glitch?
If Use Partial Loading in your Assembly Options is toggled "on" then untoggle it.
Or maybe open the part with the model in it first, and then the drawing file, to see if the error comes up.
