Valves heat loss - multiplication factors
Some time ago, here in this forum i posted a thread asking about how to calulate heat loss from valves. At that time my problem was solved through a document that i attach (see page 6-8, Table 4).
I've used this values, but recently i used them once more and see some strange results and i looked into them a bit more and i concluded that this values turn the results of the heat loss calculations quite big. See example for heat loss in valve:
- Through heat transfer calculations i obtained a heat loss of 300 W/m2
- If my valve is DN150 and from the table mentioned above, the mult. factor is 3,85
- The new heat loss value is 1.115 W/m2
If i have several valves to isolate, the energy save is very very big and i'm starting to wonder if this mult. factors are correct???
I think that if i assume a equivalent area of a valve 1,2x greater than a pipe with the same length and diameter, and using the 1st value (300 W/m2), maybe it would be more reallistic....
Opinions please!!
Opinions please!!
RE: Valves heat loss - multiplication factors
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
Look into Engineering Sample Problem in the attachment; equivalent length may be more precise than multiplication factor written there.
