Suppress By Expression / Feature Group
I have 2 Section's/Sketches "Sketch(9) & Sketch(11) SEE ATTACHMENT
I have a SUPPRESS BY EXPRESSION than controls them: X < 90degrees Sketch(9) is Active Sketch(11) is Suppressed
X >=90degrees Sketch (9) is Suppressed , Sketch (11) is Active
Here is where it gets funky.....
You can see I have both sketches inside a Feature Group. I also have that Feature group(13) controlled by a SUPPRESS BY EXPRESSION. What I am trying to do is Suppress Feature group(13) and turn on a additional Feature Group.
The problem is I have SUPPRESS BY EXPRESSION on the sketches (9) & (11) which are also Inside the Feature Group(13) also controlled by a suppress by expression.
Is there any way to do this inside of NX with basic expressions? Is there a If/Than expression?
Any input would be helpful. Thanks
RE: Suppress By Expression / Feature Group
You haved started two threads for the same topic. You should ask (by red-flagging and explaining) one or the other.
Also, what version of NX are you using?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
But to answer your question, YES, the Expression system does support the concept of IF/THEN/ELSE. Here is how an expression value would look for something like that:
If ( a = b ) Then ( true ) Else ( false )
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John, Thanks I will look into the If/Then/Else expression and see what I come up with.
