Slab Embed Plates
Slab Embed Plates
Slab Embed Plates
What is the best software for designing slab embed plates with headed anchors?
RE: Slab Embed Plates
Hilti Profis does a good job at checking embeded anchors with varying thickness and edge distances.
You may want to check with Hilti, but it is my understanding that Profis does NOT check the plate itself - it assumes the plate you specify is good for bending. I use HASDAS (an old dos program) for plates with studs. Don't know what is currently available.
