Practical example for using HAP SOFTWARE!
Is there any body having a document explaining or containing a practical example for how to use HAP software?
Practical example for using HAP SOFTWARE!Practical example for using HAP SOFTWARE!(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Practical example for using HAP SOFTWARE!
Also, go to http://onebuilding.org and sign up as a HAP user (it's free). Post your request there.
And check out what Carrier offers under the Training link on this page:
http://www.commercial.carrier.com/commercial/hvac/...
Finally, ask the same question with an e-mail to HAP support at:
Software.Systems@carrier.utc.com
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Contrast:
A 20,000 square foot rectangular 2-story office building, packaged VAV rooftop units. HAP input takes about 1/10 the time of eQuest. Results of each come out about the same.
Same building with external (adjacent building) shading, process chilled water loop, complex sequences of operation designed to save energy, or anything else that makes it "complicated" will require eQuest or (heaven forbid) building your own DOE2 input files
If it's a LEED job, pretty much forget about HAP unless the building and systems are extra simple. Plus, you have to do service hot water and any strange process loads as an exceptional calculation if using HAP.
Best to you,
Goober Dave
http://doe2.com/download/DOE-21E/DOE-2EngineersMan...
Although, I think the CTF factors are calculated using a different algorithm than the Laplace used in the original DOE (above).
I believe Trace, HAP and eQuest are all CTF/heat balance. CLTD has been "discontinued" as per ASHRAE handbook of fundamentals; although thousands of buildings are still designed with this method. There is another software tool that can do RTS, although results all are all about the same.
well, in recent years i rarely found the difference that would justify special attention to some of methods. i tried rts, but did not find much difference to cltd, and if you observe basic assumptions, sometimes it can go even to no-difference situation - if you have difference of 8-10% and that much you can influence by arbitrary decision about basic assumptions, than it is hardly worth spending time on those differences.
ctf should be somewhat wider in allowing more choice on construction elements.
