Need some help: transition surface/solid
Hi all,
need some help or advice. Look at the attaced prt file (nx7). I need to create transition between (150mm) two rails (bigger one is standard R65 type rail, and smaller one is switch-blade rail). Transition surface should be tangent to corresponding surfaces of each rail. I tried using "bridge curve" and then "surface through curves", but the result is not very good.
Thanks.
We are using NX7 64 bit
RE: Need some help: transition surface/solid
Is this what you were looking for (see attached model)? I used a 'Through Curves' surface with 'Point' alignment (double-click on the 'Trough Curves' feature to see what I mean by that).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Once you pick a point system assign corresponding point on the other side, if that point is acceptable, you can keep or else move the sphere to the nearest end point using snap point option. Check has to be done for all the points,
Hint : check the system drawn line between those two points for all alignments
Raj
NX 7.5
Here the catch is, if you keep your cursor on the existing alignment point, it gives the option to move and snap to the specified point. If your cursor is on the curve and pick a point it adds alignment points with a construction line. You practice using simple alignment using just a line and arc with Through curves, then you will get the flow.
Raj
NX 7.5
Delete ( synchronous) the small blends before creating the transition. Add new blends after.
I assume that the problems arise since we are trying to create a "super transition", many faces and many constraints at the same time, and the math model that works for the big-flat faces don't work for the small-curved faces at the same time.
Tomas
Of course, if the two sections had had the same number of segments (curves) representing the same basic topology (flat areas lining-up with flat areas, blends lining-up with blends) then there would have been NO need for using the point alignment scheme in the first place.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Of course.
Proud Member of the Reality-Based Community..
To the toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
JCBCad: I think you posted prt file from another topic :)
Anyway thanks :)
