Transport of Tested PSV's
Hi Guys,
first post, so be gentle with me smile
I need to come up with a way of transporting freshly tested PSV's to site.
They will be on the back of a truck and the roads will be rough.
It is currently the clients procedure not to transport tested PSV's, but to test them at their specific location and fit.
That procedure will be changing shortly and they have asked if i can come up with a way of transporting them without damaging the seats.
Possibly some sort of cradle, not sure, just throwing ideas out there.
Does anyone use, or has used a method or piece of equipment that will do the job.
RE: Transport of Tested PSV's
Air-ride trailer?
The guys pick them up from our Safety Valve Test/Repair Shop, put them in the back of their buggy/golf cart, and drive to the field. If the PSV is small it goes in a bucket. If it's large, it lays in the back. No special ride or rules. The plant speed limit is 11.5 mph. It's been this way for decades, and knock on wood, no problems that we know of. I think in most cases, this concern is much to do over nothing. There may be some rare cases to consider, but . . . reasonable care will usually work.
However, I understand the client relationship. Some tough, flexible work mats for the back of the truck will help for the PSVs and more! Do NOT pack them in styrfoam peanuts or something similar, someone will install the PSV with them still packed into the PSV inlet!
Good luck,
Latexman
Thanks for the replies guys, unfortunately some of our guys may have to travel 4 hours through rough australian outback on terrible tracks, so the PSV's could take a bit of a hammering en-route.
If a UV valve they should at least be sampled to assure accuracy is maintained in limits.
How would you possibly sample a UV valve once it gets to site? If you could sample the valve, you might as well install a test bench and do the resets on site. The other possible issue is that we've had a few people tell us that the PSV's need to be transported upright. I've never verified this but it seems like a reasonable expectation.
Most sites I've worked (within one company) had test benches we used for non-code/non-UV testing. One site I gained the ability to adjustment within spring range of all UV valves from the State Inspector.
If test sites were not close we required VR test data accompany the valve, for legal concerns.
We use a metal pallet with slots cut in the top and 2 - bolt the larger PSV's to it for transport to and from the plant.
Thats a decent size valve ya got there mate. Thanks for the pic
