wood and metal plated truss specs
Does anyone know what the spec setion numbers are for wood and metal plated trusses? Also, where i might be able to find an example of each? I thought Masterspec had out-of-the-box examples for every section, but I guess not.
RE: wood and metal plated truss specs
The 2009 IBC has a section, 2303.4 Trusses outlines what needs to be provided (design, drawings, etc). It also referres to TPI 1 specifications. I believe that TPI 1 can be found on line.
I hope that this helps.
At http://www.masterspec.com/structural_civil_landsca... they show in the Basic Table of Contents pdf
"02/11 061753 SHOP-FABRICATED WOOD TRUSSES Metal-plate-connected members"
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
