NX Nastran: No results in SESTATIC 101solution
I'm having some problem to get the results of a linear static analisis, i've applied the loads, the constraints, and the surface-to-surface contacts, in the .f06 file, i found the error: RUN TERMINATED DUE TO EXCESSIVE PIVOT RATIO, I set the bailout to -1, so I could see the error, and the problem was in one bolt, the maximun displacement was 75mm on it. I just can't find the reason of that.
Thank you,
Arthur Lisboa
Thank you,
Arthur Lisboa
