Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love this site! It's so nice to know that there are so many people out there who are willing to share their knowledge..."
Geography
FTARunner (Automotive)
12 Sep 12 13:16
In short, I need a macro to search through the whole assembly in Catia V5 and rename or remove *.1 from the instance name.
I got up to a point where I was able to search the whole assembly, select all the parts with a *.1, but it looks for that specific part name.
Any ideas?
ferdo (Mechanical)
13 Sep 12 9:11
Can you post what you have now (code) and a picture with what you want in fact?
I think I know what you want but just to be sure (rename is a little bit different then remove...)
Fernando
https://picasaweb.google.com/102257836106335725208
13 Sep 12 9:22
Just to update; I got a macro that renamed the instance name to be the same as the part name. That works great but I wasn't looking at the whole problem.
Basic: I need a macro that will remove spaces from the part name (and instance name if able). So for example; DVR Front Door Lower Ring will change to DVRFrontDoorLowerRing.
I usually get rather large assemblies and we have to take these assemblies into another program. When it converts the geometry, it changes any spaces and periods to underscores and I end up having to go through all the part names and change them.
This is the macro. I did change a little bit, so there might be a line that is irrelevant or useless.
Sub CATMain()
Language="VBSCRIPT"
Set Documents = CATIA.documents
For Each Item In Documents
If Right(item.Name, 10) = "CATProduct" Then
Set CurrentProduct = item.Product.Products
For i = 1 To CurrentProduct.count
CurrentPartNumber = CurrentProduct.item(i).PartNumber
k = 1
For j = 1 to CurrentProduct.count
CurrentLine = CurrentProduct.item(j).PartNumber
If CurrentLine = CurrentPartNumber Then
CurrentProduct.item(j).Name = CurrentPartNumber
k = k + 1
End If
Next
Next
End If
Next
End Sub
ferdo (Mechanical)
15 Sep 12 0:35
Hi
To replace a string (in your case a blank space) only in PartNumber you can use in a CATScript
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
Set products1 = product1.Products
Dim StrToBeReplaced
Dim sLF
sLF = Chr(10)
StrToBeReplaced = InputBox("Write here string to be replaced", "Input for String to be replaced", "A string", vbOKCancel)
If StrToBeReplaced = False Then
Exit Sub
End If
Dim StrUsedForReplace
StrUsedForReplace = InputBox("Write here string to be used for replace", "Input for String to be used for replace", "A string", vbOKCancel)
If StrUsedForReplace = False Then
Exit Sub
End If
For i = 1 To products1.Count
ElementNumber = products1.Item(i).Partnumber ' Extract reference number
ElementNumberReplaced = Replace(ElementNumber, StrToBeReplaced, StrUsedForReplace)
products1.Item(i).Partnumber = ElementNumberReplaced
Next
End Sub
Fernando
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
