Need advice on torquing M12x1.75 class 10.9 bolt connecting a NV4500 transmission to an aluminum
Need advice on torquing M12x1.75 class 10.9 bolt connecting a NV4500 transmission to an aluminum Bell housing
I do not know if this is the proper forum. If not please advise.
I have a 1994 K3500 Chevy truck 6.5 Turbo Diesel
The books call for 74 ft lbs of torque with no mention of thread locker or anti-seez.
74 lbs torque sounds a little high to me, since the bolt goes to an aluminum threaded bellhousing. It also seems to me that since it is a steel bolt going to aluminum that it should have something on it.
Please advise.
Thank you much
Please advise.
Thank you much
RE: Need advice on torquing M12x1.75 class 10.9 bolt connecting a NV4500 transmission to an aluminum
I personally use Never-Seez on everything that doesn't involve plastic, and work to or below the low end of the torque range given.
Mike Halloran
Pembroke Pines, FL, USA
"Research is what I'm doing when I don't know what I'm doing."
good call, 74LBs will strip the threads,keep digging until you have the correct torque.
ref only
chev 350 trans to bell housing 25-30 ft lbs. use with caution went using un-calibrated torque wrench.
I like using thread locker for bolts to prevent it from vibrating loose.
mfgenggear
Are any of the books official GM?
Generically that torque spec may not be out line for the bolt.
http://www.imperialsupplies.com/pdf/A_FastenerTorq...
If there are 2 full diameters of thread engagement in the aluminum and there is plenty of meat (aluminum, really) around the tapped hole it >may< not be too much for the aluminum, either.
pages 66-68 here
http://www.dalecompany.com/pdf/UNBRAKO.pdf
Actually it was 2 different GM books and a Chiltons
The GM book can sometimes be hard to follow and I've had to really look to confirm that certain bolts called for sealer.
On my mind any bolt that goes to aluminum needs something on it. They are only assembled with a certain lifespan in mind. I frequently exceed that by decades and 100's of thousands of miles.
I've dealt with steel frozen in aluminum on far to many occasions to use nothing when they come in contact
Thanks for the advice.
I did torque to 74 lbs. But my torque wrench hasn't been double checked in a few years. I don't get it calibrated. I jus compare to somebody's new torque wrench on a torqued bolt
hopefully the threads where not damaged.
that amount of torque is normally on the the nut that holds the engine harmonic balancer with steel threads.
was there Inserts in the Aluminum?
any way good luck
Mfgenggear
http://www.thedieselgarage.com/forums/showthread.p...
Almost certainly larger than 12 mm
No mention of trans to bell housing
For corrosion sealing concerns and precautionary locking of assembled fasteners Loctite wicking green 290 is pretty slick if you can reach the end of the bolt/screw
Offshore Engineering&Design
http://upload.wikimedia.org/wikipedia/commons/e/eb...
When I zoom in and look at the base of the cylinders it looks like there are a brazilian large bolts securing the cylinder flange to the crankcase. I'm guessing those bolts haved sculptured, waisted shanks. Still, Bolts with a short "grip length" like that can bring on a variety of problems in a hard working joint.
The MIL spec recommendation of designing with at least 7 bolt diameters provides flexibility that goes a long way toward avoiding problems with loss of preload, and having to balance thermal expansion effects.
