Max Diff Head VS Shutoff head
Experts,
What is the difference between the MAX DIFFERENTIAL HEAD and the SHUT-OFF HEAD of a centrifugal pump?Are these the same? Thanks.
RE: Max Diff Head VS Shutoff head
Maximum Differential head is USUALLY the same, but some pumps do have curves that can rise a little bit higher than Shutoff Head over certain flowrate ranges.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
