Flat pattern
Flat pattern
Hello Everyone,
i am having some component n want to make a simple flat pattern but i cant, it give some error to me ,so any one can help me.
Thanks...
Thanks...
THANK YOU...
NITIN
UG NX 7.5
RE: Flat pattern
Second, I have to ask, when you say that you're looking for a 'simple' flat pattern (which BTW would be anything BUT 'simple') are you referring to having tried to create this flat pattern using the NX Sheet Metal module or perhaps the Aerospace Sheet Metal module?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Flat pattern
THANK YOU...
NITIN
UG NX 7.5
RE: Flat pattern
That being said, even if you would have managed to create a model which could have been converted to sheet metal, there would be no practical way to 'flatten' this model since it cannot be formed by using normal sheet metal 'break' method, but rather is 'stamped' and you would therefore need to use a die design package since that is how a part like this would be produced, as die stamping.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Flat pattern
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
305 Leo St.
Dayton, Ohio, U.S.A. 45404
Tel: 937.224.0868
Fax: 937.224.1356
http://www.buddesheetmetal.com
RE: Flat pattern
i am quite new in Sheet metal ,can any one help me to do this model in Ug nx 7.5 sheet metal module
THANK YOU...
NITIN
UG NX 7.5
RE: Flat pattern
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
