Nonlinear Analysis
Nonlinear Analysis
Hello...
I would like to do a nonlinear analysis in GT STRUDL...
Can anyone help me in it? If you have tutorial or things like that, I would love it =]
Thanks.
Thanks.
RE: Nonlinear Analysis
_____________________________________
I have been called "A storehouse of worthless information" many times.
The drop down menu under Modeling-> Nonlinear Effects has several options.
Here are a few commands that I use:
NONLINEAR EFFECTS
GEOMETRY MEMBERS EXISTING
MAXIMUM NUMBER OF ITERATIONS 25
NONLINEAR ANALYSIS
PARAMETERS
CODE AISC13 All Members
CODETOL 0.0 ALL MEMBERS
SUMMARY YES All Members
STEELGRD A36 All Members
Thank you a lot for your help.
You might consider taking the GTStrudl basic and advanced course when they are given in Atlanta. The summer courses were given in August and the spring course is taught during spring break at Georgia Tech next year.
*TITLE 'EXNL01 - HIGHLY NONLINEAR COMPRESSION-ONLY TEST'
STRUDL 'EXNL01' 'HIGHLY NONLINEAR COMPRESSION-ONLY TEST'
$* ** PROBLEM DESCRIPTION: Sample problem for Nonlinear Analysis.
PRINT GEN OFF
UNITS FEET POUNDS DEGREES
GEN 2 JOI ID 1 100 X -8.916,-1 Y -14.5
MOD 19 ID 1 Y 0.97
JOINT COORD
1001 -2.83 4.907
1002 2.83 4.907
GEN 2 JOINTS CYL Z ID 21 100 R 6.083 1 TH 180 LZ 0 OFFSET 1001
MOD 6 ID 1 TH -10
GEN 2 JOI CYL Z ID 28 100 R 11.75 1 TH 115 LZ 0
MOD 11 ID 1 TH -5
GEN 2 JOI CYL Z ID 40 100 R 6.083 1 TH 50 LZ 0 OFFSET 1002
MOD 5 ID 1 TH -10
GEN 2 JOI ID 46 100 X 8.916 1 Y 3.937
MOD 19 ID 1 Y -0.97
TYPE PLANE FRAME
GEN 64 MEMBS ID 1 1 FROM 1 1 TO 2 1
TYPE PLANE TRUSS
GEN 63 MEMBS ID 101 1 FROM 102 1 TO 2 1
STATUS SUPPORT JOI 1 65 102 TO 164
JOINT RELEASES
1 65 MOM Z
DELETIONS
JOINTS 101 165
ADDITIONS
INACTIVE JOINTS 1001 1002
UNITS INCHES
PRINT JOINT COORDINATES
UNITS INCHES
CONSTANTS
E 3.6E6 MEMBERS 1 TO 64
E 1.E6 MEMBERS 101 TO 163
MEMBER DIMENSIONS
1 TO 64 RECT B 12 H 10
MEMBER PROP PRIS
101 TO 120 144 TO 163 AX 139.68
121 TO 143 AX 152.88
$ PLOT PROJECTION
LOADING 1 'UNIFORM LOAD OF 1 KIP/FT'
MEMBER LOADS
21 TO 44 FORCE Y GLO UNIW -83.33
LOADING 2 'TEXT LOAD TO MATCH ANSYS RESULTS'
JOINT LOADS
21 TO 45 FORCE Y -713.2 $ = 17830 LBS
LOAD LIST 2
NONLINEAR EFFECTS
COMPRESSION ONLY MEMBERS 101 TO 163
MAXIMUM NUMBER OF CYCLES 1
CONVERGENCE TOLERANCE EQUIL 0.00001
NONLINEAR ANALYSIS REDUCE BAND
LIST LOADS DISPL
NONLINEAR ANALYSIS CONT
LIST LOADS DISPL
NONLINEAR ANALYSIS CONTINUE
MAXIMUM NUMBER OF CYCLES 20
OUTPUT DECIMAL 4
OUTPUT ORDERED
LIST DISPLACEMENTS
LIST LOADS
LIST REACTIONS
LIST FORCES
CONVERGENCE TOLERANCE DISPL 0.00001
MAXIMUM NUMBER OF CYCLES 25
NONLINEAR ANALYSIS
LIST DISPLACEMENTS
LIST LOADS
LIST REACTIONS
LIST FORCES
Can't you save it in a pdf file and send me?
Thank you a lot man !
The program comes with several example files that will show you what is possible with the software.
I always attend the User's Group meeting in June and people come from as far as Sri Lanka and Russia. A group from South Korea used to attend. Our last meeting was in Seattle and I believe we will be in Charlotte, NC next year.
