Thread table data
Thread table data
Thread table data
Hello all
I'm currently looking at customizing our thread table to get rid of the stuff that is not relevant to our company and adding a load more. However rather than spend hours mooching through the machinery handbook, I wondered if any of you would alreay have the data in your tables that you could copy and paste in to a reply, to save a lot of time I have already found the data for BSP threads in a link as shown below, what I also would like to get are the following.
METRIC coarse
METRIC fine
SAE
UNC
UNF
Here is the BSP I found on another post.
BSP,0,55
# British Standard Pipe Thread
# Name Major Minor Pitch Tap Drill Shaft Depth
# Dia. Dia. Dia. Dia.
# (internal (external (75% full
# threads) threads) thread)
# (mm) (mm) (mm) (mm) (mm) (mm)
1/8_BSP 9.728 8.566 0.907 8.700 9.728 12.000
1/4_BSP 13.157 11.445 1.337 11.600 13.157 16.000
3/8_BSP 16.662 14.950 1.337 15.000 16.662 18.000
1/2_BSP 20.955 18.631 1.814 19.000 20.955 20.000
5/8_BSP 22.911 20.587 1.814 20.750 22.911 21.000
3/4_BSP 26.441 24.117 1.814 24.500 26.441 22.000
7/8_BSP 30.201 27.877 1.814 28.000 30.201 23.000
1_BSP 33.249 30.291 2.309 30.500 33.249 24.000
1_1/8_BSP 37.897 34.939 2.309 35.000 37.897 25.000
1_1/4_BSP 41.910 38.952 2.309 39.500 41.910 26.000
1_3/8_BSP 44.323 41.365 2.309 41.500 44.323 27.000
1_1/2_BSP 47.803 44.845 2.309 45.000 47.803 28.000
1_3/4_BSP 53.746 50.788 2.309 51.000 53.746 30.000
2_BSP 59.614 56.656 2.309 57.000 59.614 32.000
2_1/4_BSP 65.710 62.752 2.309 63.000 65.710 33.000
2_1/2_BSP 75.184 72.226 2.309 72.500 75.184 34.000
2_3/4_BSP 81.534 78.576 2.309 79.000 81.534 35.000
3_BSP 87.884 84.926 2.309 85.500 87.884 36.000
3_1/4_BSP 93.980 91.022 2.309 91.000 93.980 37.000
3_1/2_BSP 100.330 97.372 2.309 97.750 100.330 38.000
3_3/4_BSP 106.680 103.722 2.309 104.000 106.680 39.000
4_BSP 113.030 110.072 2.309 110.500 113.030 40.000
4_1/2_BSP 125.730 122.772 2.309 123.000 125.730 42.000
5_BSP 138.430 135.472 2.309 136.000 138.430 44.000
5_1/2_BSP 151.130 148.172 2.309 148.500 151.130 46.000
6_BSP 163.830 160.872 2.309 161.500 163.830 48.000
Thanks guys.
Si.
Best regards
Simon NX7.5.4.4 MP5 - TC 8 www.jcb.com
RE: Thread table data
Here is an Internet link to some metric threads.
I cut and pasted their information directly into a spreadsheet a few days ago.
http://mdmetric.com/tech/M-thead%20600.htm
If this doesn't work I can pass on my spreadsheet to you.
Thanks Jerry
Are you pointing your EV to a spread sheet? Or are you pulling out jsut the information you require and adding it to a .dat file to satisfy the headings in the table I posted?
cheers
Si
Best regards
It would appear that you're editing the older thread table which is now only used by the Detailed Thread feature, correct? Note that most all of the information that you're looking for can be found in the newer thread data tables used for the Threaded Hole feature. Granted, they're not in a format which can be 'cut & pasted', but the data is already there.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John
I found the .xml in the modelling standards directory. Are can I therfore use this file to point the thread function to as well for external threads? Bare with me on this, as you are dealing with a rank amature when it comes to this type of config?
Best regards
External Threads, which can only be represented using Detailed Threads, use the old thread tables. The new XML file is only for the 'new' Threaded Hole feature.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John, when you say "Detailed thread" you mean "the Thread feature" ?
Since inside the Insert - Design feature - Thread, there is a choice "Symbolic / Detailed"
-I assume that both "Symbolic / Detailed" i this dialog use the old table.
Anyhow, i re-wrote the old metric table many years ago since the values for the metric threads were (probably) adapted to Inch -drills and not metric drills. ( i.e in the metric world we select a 5mm drill for an M6 thread and not a 5.1881mm drill.)
I then also... divided the table into preference "Preference class 1" and "Preference class other"
( Where typically M5, M6, M8 , M10 etc is in pref 1
and M5.5x0.5 , M7x1, M9x1 etc is in "Preference other")
Regards, Tomas
Yes, you're correct, I should said the 'traditional' Thread Feature (as opposed to the newer Threaded-Hole feature) in both it's 'Symbolic' and 'Detailed' manifestations.
BTW, welcome back. You've been 'missing in action' for awhile and was hoping that nothing untoward had occured.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks John. I have had a long vacation with my kids, that simple. smile
What ever happened to Hudson888? He used to be on here all the time and helped me out a lot, but I haven't seen him for years.
Best regards
Yes, I've wondered the same thing.
According to the Eng-Tips records, Hudson888 made his last post on September 1, 2011, however the records do show that he last logged into Eng-Tips this past August (August 3, 2012 to be exact).
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
