SKM Naming issue
SKM Naming issue
How would I rename the component with the same old name in SKM. When I try to rename the component with the same old name, it gives me a message "Non-unique name in this or other scenarios". Please note that I did no destroyed the component I have only removed it from Single line diagram before renaming.
RE: SKM Naming issue
I believe you will have to either use a new name or destroy the original component in the Base scenario and start again with a new component using the old name.
Depending on the version of SKM you have you may also find unused components by clicking on "Find Not in any One-Line" in the "Edit" menu, double click the component which will allow you to destroy it again by right clicking etc.
