Modeling Precipitation data with out a gage
I am doing a small drainage study for an area less than an acre.
The purpose of the study is to recommend solutions to correct basement flooding for a series of homes. Homeowners being as they are, really can't give me alot of information on the flow rate entering their basements or the depth of water ponding for any given flooding event. I am having to make some assumptions which will preface any design that I develop. I am looking at one major storm event which occured last fall which was particularly bad. I have NOAA data which I can use to get total rainfall volumes for the area that I am studying. The drainage shed is rather small, less than 2 acres. Since the area was small, and developed I was not planning to adjust my peak estimated inflows for time of concentration. Does any have any insight, comments or suggestions for this approach?
Al Budinsky
Skelly and Loy
Harrisburg, Pa
RE: Modeling Precipitation data with out a gage
Can you explain what you mean by this? How will you determine rainfall intensity (assuming you are using the rational method)?
