CATIA FEM- Error
CATIA FEM- Error
Hi to all
I opened one Part/Assembly in GAS/GPS Workbench for Analysis. But it Shows one Error/ Warning message that
'Part Body is empty or External View is not defined'
I hope the 'External view ' is required only for Surface model
Could you please suggest me one remedial solution ?
Situation
The assembly contains,
One casting, Matrerial Aluminium Alloy
2 cylinder and Plunger(just like shock Absorber)- and it is recomended/supposed to consider as a bar(1D) element(?)
(Is it pssible in CATIA one part is Solid(solid tetrahedron element and one part is bar element(1 D element)??)
3 A load of 1600 N applied at the top of the part
please give me a reply
thanking u in advance
Anil
Situation
Anil
RE: CATIA FEM- Error
Also, by definition, GPS is a 3D mesher, so if you don't have any solids in your part body, then it can mesh it.
Those might be the two causes of your problems that I know of.
Hope this helps.
