ETABLE on cluster
ETABLE on cluster
Hello Community,
I am having an annoying problem with the use of ETABLE in calculations on a cluster. I am solving a nonlinear structural Problem in ANSYS and use the ETABLE function to store and visualize self calculated failure criterion. Everytime I run the script on my PC, everything works fine. However, when I run it in batch mode on a cluster the ETABLE will not be saved. There are nor Errors or warnings regarding this. It just says "None defined". I am not running it in distributed mode, since I know, that ETABLE won't work there as can be read in the Distributed ANSYS Guide. Does anybody hear have a solution for this problem? Or maybe another way of visualizing independently calculated results? Thanks to everybody for your effort!
