Is it possible to create a WPS complying to both API 1104 and DNV-OS-F101
I am new to this field. I've been asked to create a WPS complying to both API 1104 and DNV-OS-F101. Is that technically possible. When i sought advice from a few seniors the only reply i got was that it is not usually done as the test requirements are very different. And qualifying the required dia and thickness range while complying to both is tricky. But is there some requirement in these two that actually contradicts each other?
RE: Is it possible to create a WPS complying to both API 1104 and DNV-OS-F101
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
