FALLING TEMPERATURE IN GAS WELL
Hello
We have gas well for the 89% of methan.
Our well is 860m deep
The temperature on the bottom is 60 celsiouse
WE MUST TO CALCULATE HOW MUSCH IS THE TEMPERATURE ON THE WELL HEAD?
HOW CAN WE CALCULATE THE TEMPERATURE FALLING?
THANKS TO EVERYBODY IN ADVANCE!
MARKO
MARKO
RE: FALLING TEMPERATURE IN GAS WELL
The ground is not homogeneous. The rate of heat transfer into (or out of) each formation is very dependent on the fluids in the formation. All of it is dependent on fluid velocity.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
