Light gauge steel bracing spacing for an open structure?
I am trying to figure out how much bottom-flange bracing to use on a LGS roof with no ceiling attached.
I am designing a car port that is open on all sides. I am in Houston, where I end up designing for 87 psf uplift.
I want to use light gauge steel roof joists, with a corrugated "R-Panel" roof over the joists.
I have a span of 20'.
I have found through tables that I can use 12 g. 10x3.25 joists @ 3' on center.
The tables say "This table assumes fully braced flanges."
Is there some spacing that I can specify strapping or even another flat Cee section on the bottom flange of the joists to brace them?
Is there tables, or some formulas? I am remembering "local flange buckling" from college... but not sure if the regular rolled steel shape formulas are valid for LGS sections.
Thank you!
--Luke
Thank you!
--Luke
--Luke
RE: Light gauge steel bracing spacing for an open structure?
