reusable pocket / pocket
what are the dependencies that in the pocket Nx7.5,8,8.5 the reference set false/model <> holeseries is used for pocketsdesign from a bolt for example? Looked at a the docs in nx8, found no information.
regards
regards
RE: reusable pocket / pocket
regards
If you want to create a pocket for the cylinder using Re-usable pocket then you need to create one more solid (actually the pocket is cut out of this)in the same part and then create a reference set False and assign it to the solid you just created.Then when you will import it inside the assembly the pocket for the cylinder (assuming it a bolt or some sort of pin) will be cut using re-usable pocket option using the FALSE reference set solid.I hope i understood your question correctly.
Kapil Sharma
As Toost said this feature is there in MOLD WIZARD for quite some time (the true reference set carries the ejecter pin or like and the false reference set contained the corresponding pocket for it) and re-usable pocket seems to be functioning that way only (you need to create a reference set FALSE and push the cylinder in that reference set in order to get a pocket).
Best Regards
Kapil Sharma
