SS Shell Rolling
SS Shell Rolling
Is it required that SS shell should be rolled on SS rollers?
What if SS is rolled on CS rollers?
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
RE: SS Shell Rolling
Better to pad the rollers, some use urethane covered rolls.
BTW I assume you are talking about rolls for handling the unit, rather than plate rolls.
Mike
thank you for valued comments.
I am talikg about the shell (for a pressure vessel) rolling from plate.
Thank you.
Nasir
Welding Engineer
PAKISTAN
Mike
The surfaces are usually then later cleaned.
If for HX service often just by blasting.
If it is a process vessel the inside will be passivated.
Plymouth Tube
For rolling thinner polished SS we have wrapped the rolls but it can be problematic.
Even heads formed at high temperatures are typically formed using CS tooling. We typically plan on pickling and passivating hot formed SS parts because they do tend to exhibit gross surface contamination.
For food service or other applications where you have to be absolutely free of contamination, pickle and passivate.
For most other applications rolling on CS rolls won't present problems if you take the basic precautions outlined above.
Nasir
Welding Engineer
PAKISTAN
