does CAD portion of NX work exactly like solid edge?
Ive never tried NX before. In terms of user interface, controls, flow, how parts are modelled etc is the CAD arm of NX essentially solid edge? Or is it different?
RE: does CAD portion of NX work exactly like solid edge?
Some common 3D CAD workflows are the same, but overall NX is way different. In some areas it's way better/more powerful, in other areas it's worse. I'm moving from Edge V20 to NX 8.0 and I love a lot of things that NX brings to the table. But it has some ancient outdated workflows and methods (coming from purly a PC centric background) that are hard wrap my head around. It lacks in drafting considerably, but advances are being made. But the one thing it has going for it is that I used to run into modeling "walls" in Solid Edge Sheet Metal and so far, I feel the barriers have been lifted. Only to be rebuilt in other places like drafting. I'm doing my best to change things and make them better and faster. And if you hate the MS Ribbon/Fluent toolbar approach as much as I do, NX will be a welcome relief. Well, up until you try a Ctrl-Tab to switch betwen open parts. winky smile
If you are a sheet metal guy, then you will find a lot of similarities in NX as sheet metal essentially comes from Edge but with some steroids.
If you have any other specific questions I would be happy to help.
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
305 Leo St.
Dayton, Ohio, U.S.A. 45404
Tel: 937.224.0868
Fax: 937.224.1356
http://www.buddesheetmetal.com
