NX open for feauture recognition
Wondering how can I extend the code bellow to recognise all design features in a model?
Will be quite useful for a simple model to recognise that there is a block and then validate its dimensions for example.
Thank you in advance
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.BlockStyler
Imports NXOpen.UF
Module NXJournal
Sub Main
Dim theUfSession As UFSession = UFSession.GetUFSession()
Dim theSession As Session = Session.GetSession()
Dim theUI As NXOpen.UI = NXOpen.UI.GetUI()
Dim theLW As NXOpen.ListingWindow = theSession.ListingWindow()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim theNXMessageBox As NXMessageBox = theUI.NXMessageBox
Dim block1 As Features.Block = CType(workPart.Features.FindObject("BLOCK(1)"), Features.Block)
Dim block_found As Features.Block = block1
If block_found IsNot Nothing Then
theUI.NXMessageBox.Show("Track Block", NXMessageBox.DialogType.Information, "Block exists")
Else
theUI.NXMessageBox.Show("Track Block", NXMessageBox.DialogType.Information, "Block does not exists")
End If
End Sub
End Module
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main
Else
End If
End Sub
End Module
