Material Liabry in Team Center
We are trying to setup our material library to reference materials within the TeamCenter environment. We want to make it such that the material properties are available to everyone and if something changes in the library that it also changes on the part level automatically. Any Suggestions?
So far I think we are going to have to setup a network location because we can't figure out how to store this data inside TeamCenter.
As always... Thanks Guys!
RE: Material Liabry in Team Center
HTH some what,
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
305 Leo St.
Dayton, Ohio, U.S.A. 45404
Tel: 937.224.0868
Fax: 937.224.1356
http://www.buddesheetmetal.com
Thanks for the reply. I really do appreciate it. Can you tell me why you gave up or explain the SQL DB you refer to and how that ties in to TeamCenter or NX?
Thanks a ton!
These tables/charts need to be updated and added to all the time when we buy new tooling or deal with new materials. We are a job shop so we run the gambit.
So we decided on a Knowlege Fusion app that is edited/input via excel by an administrator. That set of tables is updated and loaded into SQL. Once that is updated all users have access to that database in NX via the Knowlege Fusion app. The KF app populates the NX model and then back fills into Teamcenter.
Hope this helps.
Ryan
Ryan Gudorf
CAD/CAM Supervisor
305 Leo St.
Tel: 937.224.0868
Fax: 937.224.1356
