How do you setup a title block to update on all prints if original is changed?
We want to have one prt file control all other files that call out that part file so that if we adjust (as an example) the spelling on the original it updates all 3,554 prints that reference the original.
The way we are doing it now is using "IMPORT" which does not do a mass change. We are also using the TeamCenter environment and a native environment if that makes a difference.
Any help would be appreciated!!
RE: How do you setup a title block to update on all prints if original is changed?
AK
NX 7.5.5.4
But if I do go with Patterns, is there any way to store this data inside of TeamCenter instead of a local directory?
Thanks!!
AK
NX 7.5.5.4
