Copying multiple items from one assembly to another?
Is it possible? In Pro-E, I just used shift or control, and highlight the ones I want, control-C and switch to my other assembly, control-V, then add my constraints. I can't do more than one item this way in Solidworks.
David
RE: Copying multiple items from one assembly to another?
http://blogs.solidworks.com/solidworksblog/2012/08...
In this case, I have a microswitch, washers and screws in one assembly that I want to copy over to a similar assembly. If I select all of them, control-C and control-V in the other assembly, all I get is the last item. Can't believe this isn't something SW can do.
I didn't realize how much I used this in the last few years.
David
-Dustin
Professional Engineer
Pretty good with SolidWorks
David
Cheers,
Anna Wood
SW2012 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
