How to define plastic hinges in frame members using API functions of SAP2000?
I searched this board and found someone asked similar questions two years ago (but with no response). I take the liberty to ask the question:
How can we define plastic hinges in frame members (columns, beams) using API funcitons? I looked up in the function list but could not find a fuction for this purpose. In fact, I did find a funciton called "GetHingeAssigns", which gets the definition of as oppose to define plastic hinges. Besides, which API funciton should we use to extract plastic hinge responses?
Thanks!
RE: How to define plastic hinges in frame members using API functions of SAP2000?
Dear engtipline I came along with the same issue. I am basically trying to define the displacement control parameters of a plastic hinge and assign hinges to members. I found no replies on the forum so I opened a new thread:
http://www.eng-tips.com/viewthread.cfm?qid=333566
I was just wondering if you managed to find a solution to this issue?
