Open in NX7.5 a part created in NX8
What can I open a part in NX7.5 that was created in NX8?
Open in NX7.5 a part created in NX8Open in NX7.5 a part created in NX8(OP)
What can I open a part in NX7.5 that was created in NX8? Thanks Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Open in NX7.5 a part created in NX8
As far as I know all CAD systems are this way.
Sorry.
Open the part file of interest in NX 8.0. Go to...
File -> Export -> Parasolid...
...and then select the Solid/Sheet bodies that you wish to back-load into NX 7.5. Change the 'Version' setting to '22.1 - NX 7.5', hit OK, enter a file name and hit OK one more time.
Now open a session of NX 7.5, select...
File -> Open...
...and when the file 'Open' dialog comes-up change the setting on the 'Files of type:' to 'Parasolid Text Files (*.x_t)' (or whatever style of Parasolid file you chose to export). Now select the previously exported Parasolid file and hit OK and you will have an NX 7.5 file containing the unparameterized solid and sheet bodies from the original NX 8.0 Part file.
Now if you need to make some changes to these models, you can use the Synchronous Modeling tools to do so.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
How about the opposite?
How can I open a part in NX7.5 that was created in NX7?
Newer versions of NX can always open older files, just open them normally. NX will 'convert' the file to the new format behind the scenes so it may open a little slower than normal. This process is most apparent when opening large assemblies (lots of files to convert). It is usually recommended to run the 'refile_part' utility when upgrading NX (search for the term 'refile_part' in the help files for more info).
www.nxjournaling.com
